8050 stadium lights quit-suggestions?
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Topic: 8050 stadium lights quit-suggestions?
    Posted: 05 Dec 2017 at 2:06am
One of the rear lights wasn't working so I tapped on it and it flickered, tapped on it again and the rest of them quit on the back and a couple on the front,  too.  Guess I won't be doing any more chisel plowing after tonight, but would like to figure out if there's a fuse or circuit breaker or harness connection that went out.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 5:36am
These are what we run for all but the high/low pair
for the high/low i bought a pair of freightliner semi led headlights off ebay.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 5:55am
You probably had a bad filament on the back light and tapping the lamp caused a short in the bulb, blowing the fuse for the rest of the lamps. Take that bulb out and check all fuses. Merely tapping on a lamp shouldn't cause any other kind of short.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 5:56am
general comments..
I suspect the power feed is open ( no 12 volts) as all are off. The 'tapping, now all off' seems to sujest the feed wire at the bulb may be where the rest get their power from. Or it shorted to ground and blew the fuse/ tripped the breaker. Also...check where the wires run from tractor to cab, perhaps the insulation has been worn or cut due to vibration.
I like electrical problems..eazy-peezy to me...
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 10:51am
have you updated the switch in the dash? I had to do that on my 8010,, I forget what happened for sure, but the lucas switch went bad, got new one from agco, its a little different but comes with instructions..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 6:05pm
Think my 8070 has breakers.
This page was generated in 0.077 seconds.
