8050 Pto seal |
Oldred
Joined: 21 May 2010 Location: Bluffton,AB,Can Points: 148 |
Topic: 8050 Pto sealPosted: 21 Aug 2017 at 3:47am |
How common is the Pto seal to start leaking on an 8050 ? Found some small pieces of hay wrapped behind the 540 flange after the hired man (Dad) was running discbine. Got new seals at the shop ready to go should I be worried about the bearing and have one on standby before disassembly also ? Thx for any info/experience
Mark
Edited by Oldred - 21 Aug 2017 at 3:48am |
MACK
Posted: 21 Aug 2017 at 7:45am |
No, bearings are usually in good shape. MACK
Posted: 21 Aug 2017 at 9:04am |
Two seals and one Oring.
Oldred
Posted: 21 Aug 2017 at 10:37pm |
Cool Thx for replies. Got them at the shop ready to go.
Oldred
Posted: 17 Sep 2017 at 11:31pm |
Started the disassembly. How do you get the inner bearing off the end of the pto shaft right behind the big nut to get the shaft out ? Kinda puzzled ?
Didn't want to get to ruff with it just yet ? Thx Mark
MACK
Posted: 18 Sep 2017 at 6:59am |
Use a slide hammer and pull shaft out of bearing. MACK
Oldred
Posted: 18 Sep 2017 at 9:12am |
Okay Thx
Oldred
Posted: 18 Sep 2017 at 11:49am |
I take to get the bearing back on just tap on pto shaft gently for installation then ?
Thx
