8050 powershift |
scott in tenn ![]() Bronze Level ![]() Joined: 27 Oct 2009 Location: selmer tennesse Points: 68 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Aug 2015 at 3:12pm |
Was looking at a 8050 today and current owner says the only complaint he had about the tractor was getting it out off park in either high or low range. He says he had it looked at by local dealer few years back but they never found anything. Told him that was the nature of the power shift. Would appreciate any advice from the experts on here about is this normal or something is wrong before I go any further. Thanks in advance. Scott
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 789 |
Probably needs a new cable for the range shift.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8720 |
That is pretty much normal for a power shift, but there are a few tricks to get it to shift easier. Sometimes if you hold the clutch pedal hard to the floor for a couple seconds, then let it up part way, it'll shift good. In other instances, putting the power shift into reverse, and letting the clutch out a little ways, will allow an easy shift of the range shifter. Darrel
JET8070 ![]() Silver Level ![]() ![]() Joined: 06 May 2015 Location: PA Points: 60 |
If the complaint is rough shifting in and out of park, small range shift cable probly not adjusted right. If complaint is hard to get out of range, shift power shift into reverse or sometimes first gear to shift out of range. If complaint is hard to shift everything involving range shifter, check small cable adjustment. If all else fails, pull rear floor panel out and disconnect the big cable and see if it is dying. A small adjustment of the gate cable can be the difference between shifting like a new Cadillac or an old Pinto.
Thanks for all the advice. From what I was told it was only hard to get it out of park. Everything else works fine.
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2299 |
I agree with using reverse, my 8030 was hard to get out of park as long as I had it, just got used to putting in reverse and that did it and just got to be natural for me.
