8050 hose leak
7010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7010 Quote  Post ReplyReply Direct Link To This Post Topic: 8050 hose leak
    Posted: 26 Apr 2017 at 9:11pm
I came in from chisel plowing and found a leak in a hose that runs from up by the radiator area back along the frame behind the batteries.   Has anyone changed this hose before?  Any help would be appreciated.  I just got this tractor and just getting to learn about the 8000 series.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 9:41pm
Should about three hoses there follow back from cooler
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 4:53am
5 or 6 years ago we had several hoses go bad on ours and finally after I had to remove the fuel tanks to replace one I replaced every hose that was behind the tanks. I'm sure I replaced that one too. Just make sure when you put the hoses back they aren't touching the bottom of the cab. You will have a bad whine and think the hydraulic pump is out. Don't ask how I know.
Edited by wekracer - 27 Apr 2017 at 4:54am
This page was generated in 0.281 seconds.
