8030 steering and fuel issues |
aunt allis ![]() Bronze Level ![]() Joined: 15 Jul 2024 Location: East Central IL Points: 21 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jul 2024 at 11:17pm |
Replaced the main fuel supply line on a neighbors 8030 (due to sucking air) and it made a huge difference with power but after setting a few days, I still had to use the hand primer to get it started. Wondering about a ck valve in system somewhere. Also his steering cylinder is leaking pretty bad and after I topped off the hyd oil, I can't seem to get the air out of the system. Only wants to turn left. Any tricks? Sorry I dont have a manual for this tractor
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21505 |
New seal kit in the steering ram.
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 566 |
Had the same problem on a 8070. Turned out to be a leaking return to tank hose
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Thank you!!
You are more than welcome. Good luck
1984 80780
