8030 steering and fuel issues
aunt allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aunt allis Quote  Post ReplyReply Direct Link To This Post Topic: 8030 steering and fuel issues
    Posted: 15 Jul 2024 at 11:17pm
Replaced the main fuel supply line on a neighbors 8030 (due to sucking air) and it made a huge difference with power but after setting a few days, I still had to use the hand primer to get it started. Wondering about a ck valve in system somewhere. Also his steering cylinder is leaking pretty bad and after I topped off the hyd oil, I can't seem to get the air out of the system. Only wants to turn left. Any tricks? Sorry I dont have a manual for this tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 5:28am
New seal kit in the steering ram.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 1:44pm
Had the same problem on a 8070. Turned out to be a leaking return to tank hose
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote aunt allis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 10:14pm
Thank you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2024 at 10:12am
You are more than welcome. Good luck
1984 80780
1957 D14
616 tractor
