8030 Hydraulic Filters Question
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Hydraulic Filters Question
    Posted: 28 Nov 2011 at 1:09pm
While changing the hydraulic oil and filters on the semi-new to us 8030 this weekend I think I found something wrong.  I am 90% sure that when I pulled the two filters the bypass valve was installed on the right filter instead of the left filter per both the owners manual and instruction sheet that came with the AGCO filters.  If I am correct by my fuzzy memory, what kind of damage could have been done?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 10:22pm
Don't think the cap from right side will open valve on left far enough to let enough oil in to work properly. If it opened enough the only problem would be if filter pluged, the pump would not get any oil.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:15am
Mack, I wondered about the same thing and the cap from the right side is a lot longer than the by-pass valve because of the coil spring that is on the end, so I think the valve was opened and the coil spring was just compressed a lot.  I just wish I could remeber for sure how it was when I opened it up.  I pulled the cap and valve to wash in gas and set elswhere to dry, then I wasn't possitive anymore where they came from.  Although I am pretty sure they were wrong.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 12:33am
It won't work properly if you have them switched and you'll know as soon as you start the tractor.
