8030 Flasher blows main light fuse
JVan93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVan93 Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Flasher blows main light fuse
    Posted: 14 Jun 2017 at 7:28pm
Ok, now I have a electrical question relating the flasher on this 8030 s/n 1020. I found that the original flasher/turn signal unit had taken a crap and you had to tap on it to get anything to work at all. I had just assumed that another similar unit would just drop in and a away I would go.... Well the main power fuse blows everytime I run the switch to the right. The left turn and 4 ways work just fine. I have done some studying and I have discovered that there is a flasher update kit that is available...? Can I get this thru AGCO or does anyone have a suggestion?
Thanks John
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:04pm
Look at the wires where they plug into the back of the switch.
You need to cut the black wire where it comes out of the harness. That was a ground for the original switch. Connect the black wire to the dark blue wire with one of those blue scotch lock squeeze connectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVan93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:11pm
Excellent, I'll give that a try. Thanks
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVan93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:23pm
That worked perfect. Very much appreciated.
