8010 PS Throttle problem
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Topic: 8010 PS Throttle problem
    Posted: 20 Oct 2015 at 7:29am
My 8010 has started this surging of speed. It fires right up, I bring it to 1500 and it wants to run up to 2000 rpm. Then back to 1500. It'll stay there for awhile then back to 2000ish. Also while pulling up hill it doesn't keep speed, I have to throttle it up manually or it slows almost to a lugging stop.
I'm going to change the fuel filters, but they are new. Less than 20 hours and I drained the first filter, got very little water.
Any ideas?
Thanks in advance
Joe
PS after a while it will run fine at idle.
Edited by JCFarms - 20 Oct 2015 at 7:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:04am
Sounds like possible sticky metering valve to me. How many hours??? more than 5,000??
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:13am
Little less than 3000 hrs. Says the meter.
Is that valve in the injection pump?
2685 hours.
Edited by JCFarms - 20 Oct 2015 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:26am
Yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:29am
You reckon it's water?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:38am
I think you've had something other than clean diesel fuel go thru the injection pump, scratching the metering valve. That's what I think.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:40am
This is an early tractor with the Stanadyne pump right? The problems you describe sound like AMBAC M100 problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:58am
Thank You.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 11:19am
Yes. 1983 stanadyne. Going to change filters if I find any at napa. I have a field of hay I have to get cut.
Edited by JCFarms - 20 Oct 2015 at 11:19am
ChadB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChadB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 12:39pm
Mack my 8010 has the AMBAC M100 pump that does the same thing as the OP does. What are the problems with the AMBAC M100 pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChadB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 12:40pm
Sorry Mack, I ment Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 3:25pm
The Ambac has a slip clutch that will slip, and allow rpms to go above intended speed if load suddenly goes away, or you rapidly go wide open with light to no loads. The op having a Roosa DM likely has the metering valve sticking just like Dr said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 6:52pm
Fuel supply problem was the cause. Cutting hay as I type.
Edited by JCFarms - 21 Oct 2015 at 11:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 7:56am
