8010 injection pump leak
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Topic: 8010 injection pump leak
    Posted: 09 May 2012 at 8:52am
 just notied a substantial fuel spray from underneath the  top piece of the pump that has the 6 fitting for the injector lines. it appears to be from an area where there is a rectangular ( small cut out piece0 and is spraying directly rearward.  is this just a gasket or?? What all does it  take to fix it?? This is  the ambac pump.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 12:16pm
head seal of pump is leaking. It is not an easy fix, nor will just an o-ring fix it. the o-ring wears a groove in the housing. We send housings off to have them machined and an insert put in that area. Time for a pump job. Ed.
This page was generated in 0.049 seconds.
