8010 Hydraulic Pump Noise |
PAFarmer ![]() Bronze Level ![]() ![]() Joined: 06 Oct 2020 Location: Pennsylvania Points: 114 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Oct 2020 at 12:03pm |
Hello,
Over the years I've got some very useful information on this forum and I'm hopeful someone might be able to shed some light on a recent issue with our 8010. Over the weekend I was sowing wheat and after 39 years and 10k hours of operation the soft hose that goes from the main piston pump under the tractor to the valve body for the remotes rubbed thru. It didn't blow and spray everywhere but it had a pretty good stream running out. I caught it when I got out to check the drill, but otherwise never noticed anything amiss with the operation of the tractor. No noises or lack of hydraulic pressure. I shut the tractor down and removed the old hose. My local parts store was out of 3/4" hose so it ended up going overnight to the next afternoon when I could get a hose made. After installing the hose and adding around 4.5 or 5 gallons of oil we started the tractor. Before the engine even fired, I noticed a noise coming from the pump which I accounted to air in the system. Well, long story short the noise has not gone away. It sounds like a blower or something running and the noise certainly seems to be coming from the piston pump. When you move the remotes, it shuts up for the most part but still doesn't sound quite right. We changed the hydraulic oil filter, which wasn't even a year old as it got replaced at the beginning of hay making as it always does. I don't have the maintenance log handy, but I'd guess it got changed in late April. When we did that, and started the tractor it sounded normal for maybe 30 seconds or so and then went back to making the noise. It almost sounds like it under a lot of pressure. The hydraulics seem to be working just as I would expect and no issues other than the noise are showing themselves. I can't think the pump ran dry as we only added at most 5 gallons to a 17 gallon system which I know was in the top sight glass when I started the day. I'm really obsessive about checking that stuff before every day. Any insight would be massively appreciated. Thank you.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21967 |
Your new hose is touching the cab somewhere. Usual suspects are the diff lock pedal area or where the hose exits under the cab to connect to the valve stack. Big zip ties will help position it away from the diff lock area.
Well, that's simultaneously releaving and embarrassing. I know it's touching the cab! I'll fix that this evening and report back!
Edited by PAFarmer - 06 Oct 2020 at 1:28pm |
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
I had the exact thing happen about 10 years ago on the 8050. I’m pretty sure Dr pointed it out to me then |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8645 |
For a cheap fix,you can afford to be embarrassed.
Well, it took me a few days to get to it, but that straightend it out. It sounds like it should! Thanks much for the help!
