8010 FWA Tire Size
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 8010 FWA Tire Size
    Posted: 13 Mar 2022 at 5:27pm
I want to replace the 20.8 R38 rear tires with 18.4’s. Right now it has 14.9 R28’s on the front. Will these match up better with R38’s or R42’s?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 7:08pm
Tim, I think you will want 18.4 R42 with 14.9 R28 on the front.   18.4 38 went with 13.6x28 on the front.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2022 at 8:20pm
18.4x42 will make the tractor sit more level and not look like it's always going uphill
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2022 at 9:48am
If you are setting up for 30 inch rows and want to turn shorter go with the 13.6 x 28 on the front. I did this with my 8030 to fit better in the rows and turn shorter.
rieg
This page was generated in 0.234 seconds.
