8010 exhaust relocation |
kinghunter
Joined: 30 Jan 2010 Location: Kansas/Missouri Points: 408 |
Topic: 8010 exhaust relocationPosted: 25 Apr 2018 at 11:49am |
Would turbo elbo off a 190/7000 bolt to 8010? I’d like to get all the heat out of the engine bay and straight pipe tractor. I understand I’ll have to move exhaust hole in hood to other side. I plan on welding other hole up and painting hood. This should let things under hood run a lot cooler.
kinghunter
Posted: 25 Apr 2018 at 6:45pm |
? No ones changed exhaust on 8000 series
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1226 |
Posted: 25 Apr 2018 at 7:08pm |
Check with Thomure muffler, not sure about the spelling, 800-527-9954. He could help you out.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 25 Apr 2018 at 8:10pm |
Before making modifications, I would diagnose why it is running hot.
kinghunter
Posted: 25 Apr 2018 at 8:23pm |
Tractor doesn’t run hot. But it be a lot cooler under hood with all that exhaust removed. Seems crazy to stuff all that under there
smitty78
Posted: 25 Apr 2018 at 8:40pm |
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
You can get a muffler eleminator, and it will be a straight pipe out the same hole
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3603 |
Posted: 25 Apr 2018 at 9:55pm |
kinghunter
Posted: 26 Apr 2018 at 1:20am |
Guesse everyone missed the question in post. I for one don’t find a kit on thomures page for a 8010 and for two don’t see the reason to keep a exhaust pipe so close to A. C. Compressor. Thanks for responding just going move it to we’re it should have been on other side of hood. Was just wanting to know if elbow for 190 would fit is all.
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1167 |
Posted: 26 Apr 2018 at 7:07am |
Ive seen 8000s with straight pipes and not had to cut another hole in the hood. I almost bought one with a straight pipe. How they did it, im not for sure, but a muffler shop should be able to get you something set up. There is less under the hood on an 8010 than on a 8070, i dont find mine being too hot. A motor is going to run a certain temperature range. So there is going to be a certain amount of heat coming from any type of exaust under the hood. The fan helps push the higher heat back and out under the hood. I would look a little more for what you might need instead of cutting and drilling a new hole, but just an opinion.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Posted: 26 Apr 2018 at 7:10am |
Elbow from other models will bolt right on to the turbo.
Michael V (NM)
Posted: 27 Apr 2018 at 2:29pm |
I would also like to do this,, just to get that blasted exhaust pipe away from the AC compressor,, I guess theres not many here who have had to service the AC on an 8010, those service fittings are really close to the exhaust pipe..
I glanced at my 8010 this morning,,a quick glance,,, could the turbo be turned 180*? or does that put the exhaust to close to the side panel? or to many other problems created? this would make the intake side straight in,, exhaust facing to the rear..
kinghunter
Posted: 27 Apr 2018 at 5:40pm |
That’s one primary reasons doing this. I have a large scar from refilling AC compressor. To find out heat from exhaust keeps killing new fittings. I’ve looked at turning turbo around also and just straight out and up. I think I’ll go straight out and up.
Posted: 27 Apr 2018 at 6:29pm |
Been a long time since I looked under the hood of an 8010 tractor. How about simply moving the A/C compressor over 1 inch ?? (use same OEM belt?) and then sliding in a heat shield between the hot pipe and compressor ?? The muffler eliminator would help reduce overall underhood heat, but that hot pipe would still be close to the compressor.
kinghunter
Posted: 27 Apr 2018 at 8:59pm |
To late dr. Just too hole saw and cut a 6 inch hole in hood and welded other side up. Took a lot of pipe out under there. Looks much cleaner
Mikez
Posted: 27 Apr 2018 at 9:34pm |
Show some pictures
Michael V (NM)
Posted: 27 Apr 2018 at 9:44pm |
What I would have done, is, cut the original hole out,, figured out where the new one would go, cut it out, weld in factory hole in the new place, put the cutout back where old hole was...yea,, yea,,, I know,, lotsa body work, but would look good..
Did ya just cut and reweld the elbow out of the turbo?..that looks easy enough |
kinghunter
Posted: 28 Apr 2018 at 5:41am |
I’ll get pics when I get chance. I rewelded hole. Ground down smooth. When I’m done painting won’t know any difference. I used turbo elbo off 190 turbo I had Layin on shelf. Figure I’ll sell muffler turbo and pipes to some originalist.
Bobbyg
Joined: 04 Feb 2018 Location: Rogersville,al Points: 5 |
Posted: 24 Nov 2020 at 4:44pm |
did you sell your muffler for 8010?if not how much? Would you ship, to 35652
Thanks. Bobbygolden
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 259 |
Posted: 24 Nov 2020 at 5:22pm |
Does your 8010 not have a asperator tube on it, both my 8010's have them witch I think is a good idea ? Dave
kinghunter
Posted: 29 Nov 2020 at 12:57am |
No mine didn’t have asp. Tube. 7010 exhaust turbo flange had correct offset to miss air filter tube that run along tin and put hole through hood. No I didn’t sell any of original exhaust parts. Not sure I will. Figure I’ll sell them with tractor some day incase someone wants put back original.
Edited by kinghunter - 29 Nov 2020 at 12:59am |
NEVER green
Posted: 29 Nov 2020 at 9:34am |
I see Im too late but I wrapped one of my 8050 s with exhaust wrap, helps a lot.
