8010 AC
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Topic: 8010 AC
    Posted: 14 Oct 2016 at 11:20pm
Quit blowing. No fans and compressor not coming on either. Anybody got any suggestions on where to start looking? Fuses maybe? Where would it be located? I've removed the lower dash panel, I see breakers it looks like to be. Everything has got power under there......
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 11:48pm
your fan switch I think is what turns the compressor on/off along with the fan, check it too
charlesbendal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlesbendal Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 6:39am
The compressor won't kick on without the fan so it's definitely in the fan circuit. Check the fuses that's easiest then start checking wires chances are it's a bad connection somewhere. You will probably have to take the plate off the roof
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 6:45am
Fan switch are not the best quallity. May have burned a terminal off.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 10:37pm
Fan Switch! Burnt the bat. Terminal off. $10 at napa. Fixed it from inside the cab.
Thanks Guys. It was the first thing I checked this am. Got the bailing done for the year!
This page was generated in 0.067 seconds.
