8000 series differential Lock
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series differential Lock
    Posted: 30 Apr 2018 at 9:42pm
Greetings all,
I was curious if you might be able to shed some light on the differential lock in my 8000 series Tractors (8010 and 8050).  When I read in the O/O manual, it states that "use of the pedal engages the differential lock so both rear wheels must travel at the same speed".
It also states that the "The differential lock is disengages by depressing one or both brake pedals".
How does that work?  I am curious how this is done mechanically in the transmission/rear end?  Additionally, I am curious if there was a way to know if it was fully disengaged?  If it does not fully disengage, will I feel or hear something?
Thank you for your help.
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 6:13am
I believe it is actuated hydraulically. If it’s not disengaged you’ll know it. It won’t turn worth a darn.
