8000 series cab ???
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series cab ???
    Posted: 05 Jun 2017 at 12:53pm
I would like to gather some ideas how people run cabling for planter or baler monitors in and out of the cabs on these tractors. I will be pulling a couple different balers and will need to be able to hook and unhook as easily as possible. I had kinda thought of putting an access hole or door at the left side of the lower rear window. Is there a grommet kit sold by anyone for such purpose? I hate to butcher the cab, so I am looking for advise. Thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 2:01pm
Provisions under and behind the seat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 5:54pm
Are you saying the two plates, one under and one behind the seat are where you are supposed to cut your own opening?
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 6:13pm
Mine unbolted and allowed me to just set the wires in.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 7:09pm
What we did with our 8000's, was to remove the plate under the seat, where the flow adjustment rods come through. Once the plate is out, you can cut a hole to fit a 2" schedule 40 steel pipe, with threads on one end. Weld the pipe into the plate, with the threads to the outside. Re-install the plate. Pass your largest connection through first, then the smaller connectors. Stuff foam rubber around the wires, to keep dust out. When not in use, you can cap the pipe off with a threaded pipe cap.
Edited by bigal121892 - 05 Jun 2017 at 7:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 9:37pm
I like the idea, I may use a hole saw, and then a PVC male adapter and coupling, that would achieve the same result without removal for welding. Thanks
Allis Express
