8000 ether injector
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: 8000 ether injector
    Posted: 05 Apr 2023 at 10:01pm
How is this thing designed to work? Was playing with it on the bench to see what kind of squirt it produced. It appears to release a squirt when power is removed. That is to say that it doesn't spray contineuos when energized I think. The rubber gasket isn't sealing top of can and the bail is tight. Anyone know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 5:45am
Designed that way so someone couldn't just hold the button down causing a whole can to unload.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 6:43am
Thanks Doc. Makes sense.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 7:28am
solenoid goes down into can spray stem, but is basically blocking flow until it retracts when you let off button. We used to drill out the orifice some to help with really cold temps.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 8:23am
Make sure you have the right can for that kit top on some can don't fit right
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 8:28am
Best practice is to disconnect the wire and leave that way.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 9:31am
Agree, for the most part. Ether is like booze, can cause lots of problems if not used in moderation. Lol. And there are a few who think that if a little bit is good, a lot is better. My son learned the hard expensive way about the side effects of using too much of it.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 1:52pm
Removed it from M&W tractor. Not needed. Thought would have available on the "new" stocker just incase. Emergency use only. Almost never start my tractors in cold weather. Usually near a drop cord in a shed.
The leaky can is JD. Cant get the bail to loosen on the AGCO can from M&W tractor.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 10:28pm
Most times the can leaks at gasket is because nozzle in manifold is plugged.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 10:35pm
Got threads cleaned up on bail adjuster and cleaned up top gasket. Got it together and snugged up. Works as designed. Had tube and nozzle on bench as well. One shot looks like plenty to me. Moved nozzle to intake tube after a/cleaner. Tube is zip tied to air cleaner to prevent vibration fracture. This will need monitored because its now on the suction side VS pressure side. Two prong plug is only on one prong. It can't be used accidentally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 11:24pm
Many of them are wired such that the ONLY way they work is when the starter button is pushed and being held, that the ether button will only work then.
This page was generated in 0.088 seconds.
