8000 AC cost
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 8000 AC cost
    Posted: 21 Dec 2017 at 3:13pm
Hi all. What would be the worst case cost on getting AC working on 8010. I would assume that would be the compressor expansion tank and What else is big dollars in there. Just wondering. Was gana go look at a tractor and wanted to have price in mind. Thanks
Edited by Mikez - 21 Dec 2017 at 3:14pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 3:20pm
My L2 needed a new compressor, drier, expansion valve and since I didn't have time I hired it done = ~ $1,200. That was 3 years ago.
Wink
I am a Russian Bot
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 3:22pm
Who is doing the work?   You or a shop?
Parts and refrigerant alone could run well over a grand IF you have to replace everything.  You did say worst case right.......now it is unlikely you will need to change your condenser, somewhat unlikely that you would need to change the evaporator, but entirely likely you may need to change the compressor, and consumables.
Best guess knowing nothing more than that, between 100 and 500 in parts you buy aftermarket.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 3:37pm
Yea would just be parts cost. We will do the wrenching. Thanks
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 10:46pm
Here is a picture of a 7060 that I put redid the A/C system in about 10 to 15 years ago.  I used an HR6 compressor instead of the old A6 unit.  I cut new brackets for it to weld on the old compressor mount plate, I think I used just 1/4 steel plate.  Used the same A/C belt and location.  The lines all hook up the same.  I had a hose shop make up new lines and replaced the dryer.  Flushed out the evaporator and condenser with brake clean.  I never had to touch the system again, sold it a few years ago.
Here is a link to the style of compressor I used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 10:56pm
I just put that compressor number into rock auto and it was only $232 there.  Thats a pretty good price for a new, not reman, unit.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 7:37am
Try AP Air Inc. About 5 years ago I installed their A6 replacement kit for 134a in my 7060 & it's still running cold. Here's a link to the AC 8010 parts
https://www.apairinc.com/shopping/?model=11378
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 7:49am
How much commonality is there to the AC components between 7000 and 8000 series tractors?
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 3:00pm
I just bought all the components (nothing is being reused) for a AC 7020. I think it was $1350 for lines, evaporator, condenser, compressor, dryer, sanden kit and switches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 4:23pm
Commonality of parts between 7000 and 8000 series ?? maybe the compressor and that's about it. Everything else is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 7:31am
MikeZ, have you redone your 8010's AC yet? If so, which route did you decide?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 8:00am
Nope, the weather went down hill. We didn't make it to go look at the tractor. Thanks for all of your input, if they still have tractor and we go ill have a good idea on price to offer. Thanks
