80 T mower
bdallman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Topic: 80 T mower
    Posted: 19 May 2015 at 8:28pm
So I tried out my 80 T today to see if it works. I need to tinker with my guard and sickle tolerance a bit as they are all over the place. One thing I did notice is the twin drive arms are bent and rubbing as they rotate. This is bad enough to build up smoke from the friction. The bearings are just replaced with the proper type and they are greased.
I believe I need new drive arms for the mower. If anyone has any available please let me know.
I'm located in northeast ks.
Thanks
Brett
1954 CA, 1952 WD with Freeman Loader,1955 WD45, 1963 D19 Gas, 1984 620H, 1980’s AC Forklift, 66 All Crop Harvester, White Top Roto Baler, Misc S.C. Equip and AC Collectibles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2015 at 9:06pm
Ray,in Beattie, Kansas should be able to fix you up. HTH Tracy
