8 foot disk additional weight ? |
Pointer Hollow Farm
Topic: 8 foot disk additional weight ?Posted: 26 Dec 2025 at 6:26pm |
On this disk someone has welded two bolts on the frame (a set on each half), I assume to add weight to the disk. I was thinking about adding some weight and I have some wheel weights. The weights I have weigh about 140#'s each. Would it be too much to add the extra 140#'s to each side or would that be too much for the bearings, etc.
I was debatiing on doing that or adding one 140# weight in the center of the disk. Thoughts? ![]() |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5322 |
Posted: 26 Dec 2025 at 9:01pm |
Common addition of weight locally is a rail road tie cut to length. Haven’t seen them cause any issues.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4203 |
Posted: Yesterday at 6:27am |
Probably the bigger problem you'll run into is keeping the front-end on the ground. Too much weight and picking the disc up could be a problem too.
Pointer Hollow Farm
Posted: Yesterday at 7:15am |
I just added 300 pounds in weight to the front.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3132 |
Thanks(1)
Posted: Yesterday at 7:34am |
If its not cutting enough a pull type (drawbar hitch) disc is the way to go,they will cut better and you can add all the wieght you can pull no problem.
IBWD MIke
Posted: 9 hours 11 minutes ago at 6:49am |
If you've got some wheel weights laying around throw them on and give it a try.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1459 |
Posted: 8 hours 53 minutes ago at 7:07am |
Gary is one of the smart guys on this site and he does bring up an important point. The snap coupler disk is more of a finishing disk than a primary tillage implement. I have one, with new blades on it, and it works great for incorporating pre emerge herbacide. But if you want to follow your moldboard plow, especially if the ground has a lot of clay or residue, you are going to be disappointed. You can take multiple passes but that just wastes fuel and increases soil compaction. Its also not great at leveling a field. If you are just doing an acre or two, you can muddle through, but any more, look for a pull type disk.
wjohn
Posted: 7 hours 39 minutes ago at 8:21am |
+3 These are pretty lightweight disks. I got one with the intent of using it for fast/shallow last pass tillage to kill small weeds right before planting. I have an IH 470 disk for more severe tillage. You can certainly add as much weight to your mounted disk as your tractor can handle and keep the front end on the ground but I think you will reach that limit very quickly even with your added weights up front. However if you have pretty sandy soil you might be okay?
Pointer Hollow Farm
Posted: 4 hours 46 minutes ago at 11:14am |
Ok, we will give it a try!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8757 |
Posted: 4 hours 27 minutes ago at 11:33am |
Yours looks like it has OEM blades which do pretty good even without weight. Many like mine have aftermarket blades which have too much "cup" and just won't cut well. An uncle had a "10 blade" snap coupler T bar hitch wheel disc. It would chop the crap out of cornstalks and give the WD With M&W's a workout without extra weight. You needed the TB working. Your results may vary.
