8' disk with ca hitch question
ricksam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricksam Quote  Post ReplyReply Direct Link To This Post Topic: 8' disk with ca hitch question
    Posted: 11 Jun 2012 at 7:07pm
Quick question gurus...I have found an 8' allis disk currently set up to hitch to a ca. Can I convert this to snap coupler for my wd45?
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 7:30am
Yes.  I did that with my disc.  Replace the pin hitch assembly with a snap-coupler eye.  Two 5/8' bolts if I recall correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricksam Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 12:55pm
Thanks Brian... I was thinking that too but was wondering if bolting the eye to one side of the disk tounge would affect how straight the disk would pull. What was your experience?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 2:57pm
Now that you mention it, it wasn't my disk after all.  It was my rear mounted blade that I changed from pin hitch to snap-coupler eye.
I'll take a look at the disk tonight and see if I can get a picture of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 11:32am
Here are some pictures of my SC #109 disc.  Note it has the ridge reducer extensions on the back gang.
Edited by Brian F(IL) - 22 Jun 2012 at 11:36am
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 1:19pm
...or just send it to southern calif in case they don't have one at the auction i'll be going to shortly...
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricksam Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:10pm
On mine the tongue is welded together at the end so I just took the loop from my plow and bolted it to the side.  Seems to work fine...
This page was generated in 0.115 seconds.
