8.370 is fixed
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8.370 is fixed
    Posted: 15 Aug 2017 at 7:53pm
Got the 8070 with the cummins back together today. Had about 70 hours on it this spring when the bottom shaft in the transmisson decided to loose 4 teeth and stop moving. So, 2 new old gears from North side tractor we are back in business! Hope to take it to the Half Century of Progress. There was some talk a while back about a Cummins conversion on how they fit and looked. Should be in Rantoul if any one would like to see one. Randy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 7:21am
Too much torque from an 8.3???
Wink
I am a Russian Bot
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 12:42pm
Hope to see you there Randy. I'm planning on pulling the 210 there thursday. I'd like to find a motel (prolly all full) and see some of the show friday for a while, then head back home to pull in princeton friday evening. Maybe I can finally pick up the old engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 9:54pm
Hope to see you there. Torque, well, 2 wheel drive, 22 ft field cultivator with a rolling harrow. Not much behind it. Only found 3 teeth of the 4 missing. I have had the tractor for 900 hours. didnt find anything when i changed the oil when i got it, also took the pump screen out then. Denny at North side said once in a while they see that gear do that.
This page was generated in 0.058 seconds.
