7GB track loader |
Larry O F
Topic: 7GB track loaderPosted: 19 Jul 2021 at 4:02pm |
I am in need of parts for my 7gb track loader. The outside bearing for final drive shaft number A23196-0 or Fiat allis number 70629354. Also need the Nut number 70081242 and nut sprocket retaining number 70621241. Can anyone help?
Thank you.
Lazyts
Posted: 19 Jul 2021 at 7:33pm |
The bearing comes up at Minnpar.com. Shows no stock- not sure if it is still available. Might want to check the dismantled listings on Machinery Trader...?
gemdozer
Posted: 19 Jul 2021 at 7:45pm |
I check tomorrow if am still have these parts and comback to you.
Larry O F
Posted: 19 Jul 2021 at 9:01pm |
Thank you.
gemdozer
Posted: 20 Jul 2021 at 11:40am |
I have 1 used double bearing with 2 cup and have the big nut and have new seal rings and boot spring assambly for HD7.
gemdozer@hotmail.com
Larry O F
Posted: 20 Jul 2021 at 2:36pm |
I have sent you an email. I am interested in the parts.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 20 Jul 2021 at 3:41pm |
7 and 7gb are different machines. make sure you are on the same page here.
Larry O F
Posted: 20 Jul 2021 at 3:51pm |
I believe the 7hd and 7gb use the same final output shaft components. If that is not correct let me know.
gemdozer
Posted: 20 Jul 2021 at 5:26pm |
The 7g and 7gb use the same outpout shaft and components only the ring sprocket is different.
Larry O F
Posted: 20 Jul 2021 at 5:57pm |
What about the 7HD? Is it the same.
CAL(KS)
Posted: 21 Jul 2021 at 7:13am |
HD7G is 20 years newer uses double reduction finals and 7GB is an update basically the same. Which machine do you have?
Larry O F
Posted: 21 Jul 2021 at 10:33am |
I have a 7gb track loader 1972.
CAL(KS)
Posted: 21 Jul 2021 at 11:43am |
ok. no worries then.
Larry O F
Posted: 03 Sep 2021 at 5:57pm |
Thanks to Hector my 7GB digs again.
