7580 HELP |
surplus_salvage ![]() Bronze Level ![]() ![]() Joined: 25 Jul 2011 Location: North Carolina Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jan 2012 at 6:52pm |
I've got a 7580 that I'm having trouble with and looking some help. The pto works fine until the oil heats up and then it almost stops. Anyone had experience like this? I'm thinking that since it is a wet system that oil is passing by somewhere, but that's just my thinking. Any help would be appreciated.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21906 |
Almost stops with a heavy load on it??? need to be checking pressures to the clutch which the test ports are right back there above the PTO shield and to the right on the cover to the PTO clutch. If it's really slipping under load, the clutch is surely fried by now....does the PTO shaft stop when out of gear?????
Yes, it really turns slow under load. When out of gear the pto shaft does not completely stop if nothing is coupled to it. You can almost stop it from turning with your hand.
