7580 gages |
TrentH
Topic: 7580 gagesPosted: 11 hours 37 minutes ago at 4:38pm |
I have a 7580 that the temp and fuel gauge are all over the place when the tractor is running and when you turn the lights on the tac bogs down I’ve cleaned the main ground cable and no difference in how they act, the other odd thing is that after I cleaned the ground cable the self test of the warning lights worked for 5 seconds and quit but it still will start with the button. Any help is greatly appreciated.
Posted: 10 hours 5 minutes ago at 6:10pm |
Start by unplugging the two harness connections straight ahead of the brake pedals, in the engine bay. Spray WD40 all over the prongs and re-connect them back together fully. Inspect for rust/corrosion or any wiring issues in that area.
TrentH
Posted: 9 hours 32 minutes ago at 6:43pm |
Alright I’ll have to pull those when I split it to do the power director anyway so hopefully that’s the problem.
Posted: 9 hours 16 minutes ago at 6:59pm |
Sometimes when I have those connections separated, I will take a needle nose pliers and twist each male spade just a bit so they fit tight when you re-couple them.
