712H Questions
kawestonltd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kawestonltd Quote  Post ReplyReply Direct Link To This Post Topic: 712H Questions
    Posted: 08 May 2012 at 7:21pm
I just picked up a 712H (old, with pod lights) with a 42" mower, tiller, and harrow attachments. It also has the electric lift option. This wasn't working when I bought the tractor ("I think it's a short in the wiring..." - Seller), and although I have gotten the electric lift motor to make some noise on a bench, I'm not having much luck with it on the tractor. The switch is working fine. Anyone have any experience with this setup? It must've worked well, because the manual lift lever is gone. Smile
Another thing it's missing is a seat. Any (cheap) options? I'm thinking I should be able to find any used seat and make it fit. Thoughts?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 10:48pm
You might ask your question here:   http://www.simpletractors.com/club2/forum.asp?FORUM_ID=7
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 7:21am
The wiring on the electric lifts get pretty beat-up and shoddy being under the machine, so you may have to rewire to the motor. Low voltage won't cut it to that motor. It needs 12V's to fly. Also check the connections at the junction block under the hood near the Ignition switch. That's out in the open where the elements can play havoc with it. When I restored my 716H, I glassbeaded that whole junction block and all the terminals cleaned up nicely on it. The 700 machines are great machines! They are tough workhorses. I'm putting together another 716H for my nephew in MD. to plow snow with. He saw mine and had to have the other one I had, so I'm hotrodding the other one for him. I'm not gonna put tailights and four way flashers on his like I did mine. When we lived on Rt 519, it was a pretty busy road, so I installed the tailights and flashers so when I was plowing out near the county road I would be seen better. Coarse, the bright Orange tractor helped also.....  LOL!Big smile
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 8:52am
Purchased a 716H new July 1976. Couple days ago I replaced the cone and pulley that drives the mower deck or other tools, installed a new set of blades on the 48" deck and a new belt that drives the 3 blades plus changed the oil. Unit is now ready to cut grass.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote kawestonltd Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 8:32pm
My lift was disconnected when I bought it, as the previous owner was troubleshooting it. When I removed the dash and looked at the lift switch, a green wire (assuming ground) was floating free, and I still don't know where that was connected. The other two wires connect to the two lift motor leads.
This page was generated in 0.032 seconds.
