7080 Water Pump
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 7080 Water Pump
    Posted: 12 Aug 2015 at 11:58pm
How does one go about getting the spacer off of the pump shaft? It has been on there a day or two and doesn't want to come off. Do I dare use heat?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 2:39am
press? uh...what spacer? behind the pulley mount? I've taken one apart before to put the new kit in it, but don't remember any spacer...
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 2:40am
your getting forgetful Shameless
Edited by dpower - 13 Aug 2015 at 2:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 2:45am
ya think?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 5:35am
Sometimes those can be an absolute bitch. Plenty of penetrating oil, heat and beat, and I use a very thin screwdriver or stiff putty knife driven between the pulley and spacer.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 6:39am
Have a helper hold a heavy block on one side while you use a dull chisel on other side.  p MACK
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 1:31pm
I use a 20 ton press with a split bearing puller behind the spacer, keep tightening the bolts on the bearing puller halves as it goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 4:17pm
It is off. I used heat and little by little, she came off the end.
