7080 rpms
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 7080 rpms
    Posted: 25 Apr 2011 at 9:20pm
How many rpm's can a 7080 be safely ran at without worrying about the motor coming apart?  From what I have heard if you keep the rpm's down a little they will last alot longer  Finally got the tach and gauges working so I'm not flying blind.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 9:34pm
I run mine around 23-2400 rpms. Pulls a 34 ft feild cultivator to easily. If it hits a tough spot just push on the foot trottle to get through it. It will make the motor last a bit longer
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 9:42pm
yeah, i've been disking the same way, keeping it down about 2300 rpms too! sure can tell the dif on fuel consumption too!
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:08pm
Is say im running around 2100 to 2300, my tach doesnt work but I know its not near wound out. I do like Daehler does also.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 11:00pm
I dont know whats wrong with my 7060 but wide open it runs at 3200rpm. I run around 2400 with it and push the pedal for extra help sometimes. I dont even have a balanced crank like the 7080. I have noticed that more rpms doesnt really mean more power though, it lugs down pretty quick up there.
