7080 no power |
farmer_rob ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: N.Lancaster ont Points: 362 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Apr 2012 at 6:59am |
just put the recently bought 7080 on the dyno yesterday for about 30 mins but only get 130 hp out of it. this tractor has been sitting for a few yrs but had a complete engine overhual couple hundrend hrs before parking it. just recently put an injector pump from a 7580 on it . it has the tank 3/4 full of 4yr old fuel. its starts and runs fine but just doesnt have the power i was wanting. this old fuel playing a big part in not getting the power out of it??? is the pump not turned out to the hp it should be??
sorry for the long post
thanks for your help
if farming was easy everybody would be doing it
forgot to mention when the tractor is at full pin it really sounds great.. never been around a 426 with a turbo.. also the filters for fuel were changed and the filters for oil and the oil were changed aswell
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
Are you getting any smoke? Could be that the turbo is not spooling up enough to produce proper boost.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21854 |
Save yourself a lot of speculation and drain the tanks and replace with fresh fuel. Then, when you go back to the dyno have a 30 psi gauge installed on the intercooler and report back the reading under load.....should be 17 to 18 psi under load on a 70 degree F day.
yes im getting lots of smoke. do you mean is it spinning fast enough to get the boost??? i dont know.. i do know that they had to reweld the elbow that comes right after the turbo because of a hole the size of your finger. could that be anything related to the problem?? not likely im sure.. on the way home from the dealer the elbow cam apart so i turned around and took it back.. no wating for a good used elbow.. whats a new one cost??
i was thinking of doing that before i go any further . whats the easier way of drain the tanks?? i honestly havent looked at my new toy close enough. but dr allis thats the cheapest idea and i will do that first. many thanks |
I would say 4 year old fuel would be part or all the problem. What about fuel filters? Make sure the shut off cable is pulling the lever all the way back and staying there. MACK
Russ SCPA ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Southern Pa Points: 256 |
My guess with lots os smoke and low power, bad turbo, also as simply as this might sound, check the torque on the bolts holding the "intake manifold", on my 7060 the bolts will back out a sniff and then allows some boost loss.
just thinking that the elbow wouldnt cause that much lost because its after the turbo not before
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Got a clean air filter?
1957 WD45 dad's first AC
Bob wi ![]() Silver Level ![]() Joined: 06 Jun 2010 Location: Cedarburg, Wi Points: 63 |
I had 3 yr old fuel in the D-21 ( didn't use it much) it dropped 35 horse, new fuel, fuel filter's and it got it's 35 horse back and it did blow black smoke
TREVMAN ![]() Orange Level ![]() Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Dont put 4 year old fuel through your tractor! Try fresh fuel and put some diesel treatment in, itll be alright.
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Check for any (bird, mouse, cat, bee, etc.)restrictions in the entire intake system. Too much restrictions can cause overfueling and black smoke.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Besides turbo intake restrictions, check the pressure side-----make sure there are no leaks.
My SWAG is that the turbo bearings have rusted or crudded up from sitting for 4 years and the turbo isn't coming up to speed----------or the turbo is just plain worn. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
I would also double check that you have boost if any, if the dries out scaled carbon from the inside of the exhaust manifold all tried to come out at once, your turbo hot section is probably partially plugged and the compressor wheel isn't spinning. I see this often on tractors that sit a while
Still in use:
