7080 Hyd. Problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 9:44pm
7020 pumps fit. Hydraulic lines touching the cab anywhere make noise.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2022 at 1:02pm
Mike's equipment, Buhler KS should have a pump on hand.
Would be a shame to kill a running tractor when there is already plenty in salvage.
Still try to buy the 7020 if cheap, but fix it up, handy to have 2 tractors.
Edited by GM Guy - 09 Apr 2022 at 1:03pm
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2022 at 8:37am
I thought the same thing. I’m not going to kill it. I found a guy who had a used pump and he’d warranty it, so I’ve got that on the way.
7020 sold for $4,000 so I didn’t bring it home. There was a really sharp 7045 as well and it brought $10,000.
Edited by CrestonM - 10 Apr 2022 at 8:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 8:08am
I received a call, and there’s been improvement. The used pump assembly I got (all 3 pumps) is installed and the steering is back to working. He said once you bump the throttle just above idle it steers well, still takes some effort at the lowest idle speed. Supposed to check the rear remote pressures next and see what we have there, but it looks like we’re on the way to having it buttoned up.
