7060 Turbo |
ABDave
Topic: 7060 TurboPosted: 16 Feb 2018 at 11:09pm |
The turbo on my 7060 needs replacing. The wear in the shaft looks like it was starved of oil. The tractor is used to pull a 6 cubic yard scraper once in a while and a round baler at haying time. Other than that it collects dust.
I realize the engine would suffer a power loss if I run it naturally aspirated, but what might some of the other issues be? Would the inter-cooler need to be removed? 'till later Dave |
ABDave
Posted: 16 Feb 2018 at 11:15pm |
I should have said the tractor will be used.
Posted: 16 Feb 2018 at 11:21pm |
If you think you're going to operate that engine without a turbo?? Leave it in the shed and throw away the keys. You will slowly destroy that engine without proper air to it. End of story. Park it if you're not gonna fix it.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 17 Feb 2018 at 5:07am |
Some of the sponsors of this forum have new (replacement) turbo in the ~$400 (or less) range.
MACK
Posted: 17 Feb 2018 at 8:11am |
A turbo is a pretty inexpensive repair on a tractor. MACK
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 17 Feb 2018 at 8:36am |
Especially on a tractor that size! You have not priced new rear tires lately, have you? You wouldn't get half a tire for the cost of a turbo. |
Posted: 17 Feb 2018 at 10:17am |
I see a lot of scraper tractor turbo's that fail. They fail because the engines have been stalled too many times at full load. There's no oiling of the turbo when it is at full speed.
Dan Hauter
Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1270 |
Posted: 17 Feb 2018 at 7:41pm |
Contact Val or Von Leefers at Area Diesel Service in Carlinville, IL. or Des Moines, IA. They repair turbos every working day.
