7060 Temp Gauge
jjohnso6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjohnso6 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Temp Gauge
    Posted: 10 Aug 2017 at 6:51am
After the motor warms up the temp gauge goes all the way up to hot and likes to stay there. The motor is not hot, I replaced the thermostats and used a hand held laser temperature gun to check the head temp. Do I have a faulty gauge or sending unit?
Thanks,
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 7:24am
Start with the sender because it's easy and cheap. I'll bet it's the gauge.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 7:46am
I am dealing with the same issue on a 6080 right now. I have a new sending unit that I'm going to put on today as soon as I get out of the house. You can check the gauge. Pull the wire off the sending unit. The gauge should go to cold and if you ground it to the block it should go to the high mark in the red. My gauge seems ok so I got a sender. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 8:11am
The gauge can test OK and still read high....been there before.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 9:39pm
I fought a similar issue on my 7060 and I pulled one of the other plugs right beside the electric sender and ran a manual gauge from there to the dash. Both gauges work, but the factory gauge is almost always much hotter than the mechanical gauge I added in.
