7060 seat shock for Deluxe Cloth
guzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote guzzle Quote  Post ReplyReply Direct Link To This Post Topic: 7060 seat shock for Deluxe Cloth
    Posted: 14 Aug 2018 at 7:53pm
This is just a heads up for those with a 7040, 7050 or 7060  with the Deluxe Cloth seat and are in need of a new seat shock.
The shock for my deluxe cloth seat in my 7060 went south some time ago. It is a shock without the spring and ASAP tells me that it is no longer available. Part # 70262909
I found that a Gabriel 83012 is a pretty good match on physical dimensions so I ordered one. It is a heavy duty shock for big rig cab mounts. The rubber mounts on this shock do not have a metal insert in the rubber mount bushing like the original 7060 shock and the hole is closer to 1/2", too large for the original bolts. The rubber bushing is also a little too wide for the original mounting plates so some modifications were in order.
I pressed the metal bolt bushings out of the original shock and with a little lubrication they fit in the new shock's bushing with little effort. Using a box cutter, I shaved a little of the rubber bushing off each side so the bushing was the same width as the metal bolt bushing that I took from the original shock.
A test drive after mounting the shock proved it to be an excellent replacement for the original shock. It changes the ride that only had the springs that allowed the seat to bottom out on every bump to a comfortable ride that would not bottom out on the travel and was very "spongey" but controlled.
1981 AC 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 7:05am
I also need one for my 7010...
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 7:34am
Good to know. One for a 730 John Deere seat will fit as well. That's what I ended up putting in our 7045. Still isn't perfect. But much better then it was.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 8:51am
Do you know if the 8000 seat use the same shock?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:21pm
8000's use a different seat/suspension completely.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 10:00pm
And if you ever find 8000 fabric for the seat, please let us know.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 5:34pm
This explains a few things. The shock absorber in my 7010 is missing completely.Never been around an Allis much before.
This page was generated in 0.111 seconds.
