7060 gear grinding update. |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2186 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Feb 2018 at 10:13pm |
I posted about this several months ago, I did buy it and after checking pressures and inspecting the power direct clutches from underneath, we knew it had to be split. Broke in half today. So I thought I'd share a pic of the belly of the beast before we break it down. I'm lucky enough to have a damn good former AC mechanic to do the integral work for me.
Leon B MO
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Would you be willing to snap a pic of the cab half? I have never seen a cab tractor split. Thanks and good luck! BTW, nice looking shop.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
heck of a nice looking shop, but it's not a complete one! where's the beer fridge? lol and I would also like a pic of the front of the cab front end, never had mine apart
cob_crusher ![]() Silver Level ![]() ![]() Joined: 20 Dec 2011 Location: locke, ny Points: 175 |
great pics. is it pd or ps ? could you show front of tranny part shown. thanks
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8716 |
Yes that is a good looking shop. You can see the floor in most places. Mine ain't like that at all. Darrel |
When I bought this tractor it had missing glass, the door was sprung so bad the top was 3 inches from the jam, the PO said he owned it for 8 years and never tried to get AC working.
So rather than spend a bunch of time and money on the cab on a tractor that will only be a "spare", I decided to make it a half cab. I'm not done with it yet so give me some time to make it right. Leon B Mo ![]() ![]() |
It is a pd. The power shift tractors don't have this set of clutches. The trans brake seems to be trying to work when applying 150 lbs of air, so I don't have to go any deeper into the trans.
Leon B MO
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21854 |
If the trans brake is worn out (from a dragging P.D. clutch) it can be changed by removing the hydraulic pumps and reaching up inside. It isn't easy, but I've done one that way.
Thanks for the "cab" end view! If you would have had to go go deeper into the tranny,would the cab have to come off? That looks like GOBS of hoses/wires already! Please give updates. BTW, Are parts available to you and/or your mechanic?
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
No you can pull the trans without taking to cab off. You will have to remove two cab mount bolts, and support the cab, but at this point pulling the trans isn't that much more work.
Still in use:
i am getting ready to make tractor splitting stand similiar to yours. does the 2 rails that come up from the base to attach to side rails can they be moved for different width tractors ? thanks
Cob crusher,I'll get a better picture of the stands for you. The center jack and side jacks are homemade. The side jacks are two separate pieces bolted to either side, at the bottom are two pieces of tube that slide inside each other for different frame widths and the casters are height adjustable also. Center jack is adjustable also.
I already had the side console panels off. I had it split in a half a day even with the fuel tank straps giving me a fit. Not bad for my first split of anything bigger than a 200. Doc, my mechanic said he's never done one but in the AC training school back in the day they talked about being able to service trans brake, not easy, but can be serviced. Freedguy, Agco should have any of the internal parts we need, plates, springs, gaskets, O rings and such.
Leon B MO Edited by Leon B MO - 11 Feb 2018 at 5:30pm |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Looking good
leon b - thanks for additional pics. very helpful to me. i have a ac 200 & 7080. am getting ready to oh tranny on 200 to fix pop out. if you want to send me pics of closeup of stand i would appreciate it. the sliding design is clever. adjustable height is greast as well. my email is balljamess@yahoo.com. txs
For a 200 trans rebuild you will a different set of jacks, one to support torque tube and engine and one to support the rear end. I've got a set of those also.Leon B Mo
