7060 black Trans oil reading over-fill |
   AC7060IL
   Joined: 19 Aug 2012 Location: central IL Points: 3580  |
      Quote   Reply
     Topic: 7060 black Trans oil reading over-fillPosted: 14 Dec 2016 at 10:27pm  |
   Like the earlier 100 series AC. Tractor (170,180,185,190,200), will the newer 7010-7080's power director and/or power shift transmission compartment seals go bad, thus allowing rear-end (differential) oil to transfer into transmission housing?  Or, is there another culprit (hydraulic pump, valve, etc) that will do the same?
   MACK
      Quote   Reply
     Posted: 15 Dec 2016 at 7:04am |
    Yes, there are seals that can cause oil to transfer. Usually in hid. pump but not always. Hope some day they will make a seal that will never fail.     MACK
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
