7045 Flashers
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Flashers
    Posted: 19 Aug 2017 at 4:33pm
I know that would be a lot off people running around naked, but this is about a tractor. The flashers on the cab are not working, front or back. When I turn on the left or right turn signal the opposite light comes on solid as it should so I think the wiring and bulbs are fine. I'm thinking the flasher switch is bad. I can hear the flasher clicking but the lights don't flash. Anyone have a good switch they would like to get rid of?
AC 7045
AC 190XT with Gleaner L engine
Hesston, New Holland and New Idea hay equipment
OK, so what's the speed of dark?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 4:38pm
Did JD or IH use the same switch?
AC 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 4:50pm
With trucks and trailers, I've always found that bad grounds will cause symptoms like that.
This page was generated in 0.056 seconds.
