7040 Transmission Problems
SteveB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveB Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Transmission Problems
    Posted: 08 Apr 2018 at 11:07am
I have a AC 7040 that has problems. When cold it starts and moves but as it warms up the oil goes into the scavenger pump area and does not return to the transmission housing area.   Was wondering if the scavenger pump is out or if there is an adjustment that could be done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 12:27pm
Remove the scavenge pump and its cover and replace with the "updated" sewer pipe gravity system. Should be plenty of tractors in salvage yards that would have all the piece needed.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 1:51pm
If anyone has photos of the difference, please show us...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 8:06pm
Be sure to get or make the spacer to lower front of drawbar.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 12:33pm
I have heard of this gravity not sure how it would work? What salvage yards would you recommend calling? Thank you
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:22pm
Should be some in your area. Most around here is a long way from California.   MACK
This page was generated in 0.617 seconds.
