7040 help
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Topic: 7040 help
    Posted: 24 Sep 2016 at 6:59pm
I was bush hogging with my 7040 today and the Pto would take its self out of gear there was no particular time between when it would disengage why is it doing this?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 7:09pm
How fast are you running the engine?  When it does it, are you using the hydros? the Brakes, the Differential lock, etc. etc. etc.  Need more info on what is happening at the time of the drop out?  If you are just running along straight and level, no ancillary action, and it just drops, I would ask what is your oil level in the rear end first?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 8:01am
It seemed that it would do it when I turned and was running at Pto speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 8:12am
Are you using the brakes when you turn, even slightly?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 8:19am
Would some times but not when it would do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 8:33am
Still a reminder to double check the Hydraulic oil level in the rear end, sight gauges on the left side of the rear housing.
Do you have or have access to hydraulic test gauges, 0-3000 psi?
If so, I would test the circuit test pressure.  At the rear of the tractor on the right side....behind the right final drive planetary is the PTO valve, it sits at about a 45 degree angle to the ground.  On the outboard side should be a Tee with the rear capped off.  This is a test port.  Shut the tractor off, and install the gauge.  Start the tractor, it should read at idle or wide open throttle between 280-350 psi. with no other hydraulic activity in the system, like moving remote levers or raising the 3-point. These tractors are known to have issues with the PTO level dropping out when pressing the differential lock, but not so much with the brakes.  If that passes muster, then I would check the PTO circuit for pressure.  On the back of the tractor directly above the PTO, there is a round cover that is partially covered by the PTO shield.  There are two plugs on top of this cover.  The LEFT hand one is the PTO clutch pressure, which also gives a reading of the PTO clutch circuit, when the PTO is engaged.  This should be done with the implement PTO unhooked for safety.  When the PTO is engaged, it should read nearly identical to what you read on the other test port.  While this is engaged, try depressing the brakes and see what happens, there will likely be a minor drop in pressure, but not major, depressing the differential lock would create a larger drop in pressure.  See what happens an report back.
Remember, while this is annoying, this is somewhat normal on these tractors, but mostly only when depressing the diff. lock, so yours could have a leak somewhere, or low standby pressure.
Edited by Orange Blood - 25 Sep 2016 at 8:50am
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 9:00am
I took a bungee cord and tied the leaver forward to finish and I will chech the hydralic fluid it's been a while since i checked it.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 7:23am
Good luck. See my thread on "7045 PTO Trouble", and keep that bungee cord handy. Please let me know if you "fix it".
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 7:30am
Whenever adjusting up stand-by pressure, always shoot for 600 psi, which is different than the Service Manual spec is.
This page was generated in 0.223 seconds.
