7040 heating up differential oil
TedinOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedinOK Quote  Post ReplyReply Direct Link To This Post Topic: 7040 heating up differential oil
    Posted: 18 Jul 2015 at 6:52pm
Need some ideas as to why my 7040 heats up the rear end/final drive oil when I run the PTO brush-hogging?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 7:00pm
Do you have the proper oil in there? and at the proper level?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedinOK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 7:04pm
Been using the oil from the Ag store that says is a replacement. Could the filters restrict proper flow if they need changing ? If I stop and let idle at approx. 1000 RPM for 10 minutes it will apear to cool down some.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 8:10pm
Define heating up?  How hot is it?  How do you know this?  Did you measure it?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedinOK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 8:37pm
Hot enough final drive starts to slip. Hot enough you cannot slip the clutch without pulling the ftont wheels off the ground. Hot enough to make touching steering colum a risky business. Now you tell me how hot is that.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 8:44pm
It's probably hot from excessive slippage in the first place. I would get another opinion about the oil. If the friction modifiers in the oil are wrong there will be excessive slippage.
Edited by DougS - 18 Jul 2015 at 8:45pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 10:05pm
How does the final drives slip?
  Clutch is different oil from rear end. If it is a PD, it may be over full on oil.
  Hydraulic will run 100 degrees over what the temp. is out side. 100 to 110 degrees is as hot as the human hand can stand.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 8:44am
Oil for your clutch is the dipstick inside of the cab, and is not related to the hydraulic system or PTO. You don't say which transmission, but I'd guess it is the 20-speed Power Director with the gearshift on the floor, and the two-speed high/low buttons on the floor. Provided the oil level for the clutch/transmission is correct, it sounds like the piston seals inside the clutch are old and hard and leaking internally when the oil gets up to normal operating temps. Your perception of "hot" and normal operating temps aren't the same. There is an oil temp light on the dashboard for the hydraulic system/PTO compartment, so assuming it works ?? Normal Summer day working temps for any oil on that tractor is too hot to hold your hand on, including the steering column.
