7040 engine.. struggling up hills |
nick121
Topic: 7040 engine.. struggling up hillsPosted: 19 Jun 2017 at 10:21am |
Seemed like my 7040 was struggling up hills on the road. I was pulling a 25 foot model 2500 disc on the road, Hit some pretty good sized hills and had to down shift, Was rolling the smoke pretty good too. Not sure if the tractor is reaching full throttle or not, will have to get the tach working somehow.
Pulling a fertilizer spreader with about 8500 pounds in it was the same.. struggling up hills. I have only had the tractor a year, but don't remember it being bothered on these hills. I will check/change the air filter, any other suggestions.
old farmer
Silver Level Access
Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
Posted: 19 Jun 2017 at 10:43am |
Fuel filters and check for good fuel flow to injection pump
nick121
Posted: 19 Jun 2017 at 10:44am |
Ok, Fuel filter was changed about 100 hours ago. There is lots of black smoke.. Wouldn't that mean there is plenty of fuel? I will check all the fuel lines anyways. Might be throttle linkage. It is out of adjustment
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34628 |
Posted: 19 Jun 2017 at 10:59am |
Rolling black smoke and struggling... Sounded like an 1855 Oliver I was using one time... it was running great till we had a load of Cenex fuel come in and after that it was just got worse and worse changed out the primary and secondary filters and helped a little but soon back to being really bad... Didn't run it for anything that was hard work, but I got into a crunch and tried to plow with 5-16 behind it and 3rd gear was the best it could do... Changed out the filters one more time and boy did that thing wake up. Ran like there was almost nothing behind her and quit smoking too.
The cause of the problems was the Cenex fuel had a cleaning agent in it and had dissolved all the old residue that was in the tank and system. I would almost bet that is what is happening for you, filters not letting fuel through fast enough. |
Dans 7080
Posted: 19 Jun 2017 at 11:03am |
I have a 2500 26' itl pull the 7060 and 7080 down going up a good hill. I'd say nothing is wrong.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
JC-WI
Posted: 19 Jun 2017 at 11:10am |
Dan 7080, that on the road or in the field?
Posted: 19 Jun 2017 at 12:17pm |
Install a 30 psi gauge into the intake manifold and KNOW what is going on. That engine should be able to make 13 psi or more boost when fully loaded and performing correctly. You could have a bad turbo, blown intake manifold gasket, missing plug from the intake manifold, blown crossover hose, plugged air or fuel filter, injection pump problems, etc, etc, etc. Intake manifold pressure is the way to start diagnosing UNLESS you have access to a dynamometer.
Dans 7080
Posted: 19 Jun 2017 at 12:27pm |
On the road.
nick121
Posted: 19 Jun 2017 at 3:26pm |
Will check out all this stuff next time i'm at the farm. Im thinking air filter but maybe it's just me and the hills are bigger than I think haha.
