7040 Cylinder Disassembly
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Cylinder Disassembly
    Posted: 03 Jul 2018 at 12:59pm
Once again, I'm looking for a little help. I'm trying to get the steering cylinder apart and I've run into an odd issue. I've rebuilt many cylinders before, heck I've even been to hydraulic seal/cylinder upgrade school - this one has me stumped.
Normally it's a pretty basic deal, remove the snap ring, push in the glad until the spring retaining ring is exposed, pop that out and go to work.
My problem is the glad will not go in far enough to expose the ring. It goes in almost far enough then it's like it bottoms out on something inside the cylinder.
I've tried everything I can think of; I filled the snap ring grove thinking maybe the ring was dropping in it - didn't work. I put it in my press. It goes down as far as it does tapping it in then same thing - it bottoms out. I even tried the "drill a small hole and try pushing the spring in to get hold of it" trick, there just isn't enough room.
Has anyone ever run into this before? Any suggestions?
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 3:57pm
I have done a few of them.  Haven't run into that, yet.  That pressure port is close to the end could someone have possibly put a longer fitting in it, hitting on that collar?  Course if it was that long it would probably catch on the piston for the ram.  Maybe you can see something through that fitting?
This page was generated in 0.334 seconds.
