7030 Massey Ferguson can
waltw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Topic: 7030 Massey Ferguson can
    Posted: 08 Jun 2017 at 5:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 5:34pm
Cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 6:04pm
Oh wow, someone wanted a cab bad! I bought an A.C. 6060 a few years back andiit's got a Massey key switch,, someone worked hard to cobble that in there to save a few bucks,,! Gotta shake your head sometimes
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltw Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 6:11pm
Hey everyone, I looked. at this tractor today. It had been in a barn for years until last fall. They got it out got it going disked about ninety acres with it, he down shifted power director to turn around then up shifted to high and something came apart. He said it choked down like PD locked up. With the clutch petal pushed in the engine runs but when clutch is released engine will stall.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 7:50pm
Sounds like the power director low and high hollow shafts have seized together. It was a known problem with the early tractors.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:03am
I'll give em 10 bux for it....  Wink
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 11:03am
If it will still move in neutral the gear is seized to the shaft though.
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 11:34am
I have to admit, that Massey cab on a 7000 series doesn't look aesthetically bad to me. We all know that this was probably mounted poorly and rattles like no other, but still, that cab on that body just kind of looks right to me
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 12:28am
My 7050 did that to me this spring, it is faster to fix if you can find a good complete transmission than to try and cut the old shaft apart and remove.  The input shaft is only compatible on a 7030 and 7050 all the others are different.  The other transmissions will work in a complete swap, the input gears and shafts are different (if trying to find just the input shaft).  You can use a newer input shaft, but you will have to pull the transmission to change the gears on the counter-shaft to make it work.
