7030 Issues |
Slim
Topic: 7030 IssuesPosted: 18 Sep 2016 at 3:31pm |
On my 7030, the high range is weak. For instance when I put the tractor in gear 4, high range on the right, and then hit the left floor button, the tractor will ever so slowly start to move and then eventually build up to the appropriate speed. This is the same for gears 3, 4, and 5. It seems like there's a lack of hydraulic pressure or something. Both basket filters under the transmission are brand new. Brand new hydraulic fluid in the transmission. Power steering is weak at idle but works fine at rpm. 3-point and PTO work fine. Transmission fluid level is right where it should be with no leaks that I'm aware of.
So the question is, what could be the issue? -Slim |
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
MACK
Posted: 18 Sep 2016 at 8:44pm |
I would say the torque limiter is bad. When it is split to replace torque limiter, also pull the PD and reseal it. Not a big job and cost is not bad. MACK
Ronnie
Joined: 23 Mar 2014 Location: New Brighton Points: 557 |
Posted: 19 Sep 2016 at 4:19am |
I agree with Mack.
Had kinda of the same problem with my 7020. The seals in power director were hard and didn't won't to seal |
