7030 Issues
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: 7030 Issues
    Posted: 18 Sep 2016 at 3:31pm
On my 7030, the high range is weak. For instance when I put the tractor in gear 4, high range on the right, and then hit the left floor button, the tractor will ever so slowly start to move and then eventually build up to the appropriate speed. This is the same for gears 3, 4, and 5. It seems like there's a lack of hydraulic pressure or something. Both basket filters under the transmission are brand new. Brand new hydraulic fluid in the transmission. Power steering is weak at idle but works fine at rpm. 3-point and PTO work fine. Transmission fluid level is right where it should be with no leaks that I'm aware of.
So the question is, what could be the issue?
-Slim
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 8:44pm
I would say the torque limiter is bad. When it is split to replace torque limiter, also pull the PD and reseal it. Not a big job and cost is not bad.     MACK
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 4:19am
I agree with Mack.
Had kinda of the same problem with my 7020.
The seals in power director were hard and didn't won't to seal
