7030 hydraulic pump |
Natestol
Topic: 7030 hydraulic pumpPosted: 13 Jan 2021 at 9:04am |
7030 hydraulic pump bad and wondering if there is a manufacture out there that has different pump to fit and work?
Posted: 13 Jan 2021 at 10:19am |
Which pump?? Gerotor..….gear......or main piston pump??
Natestol
Posted: 13 Jan 2021 at 12:32pm |
Dr allis well both!? I have a piston pump bad on one tractor but I think it be nice to know either
Posted: 13 Jan 2021 at 1:33pm |
A "bad" piston pump many times isn't a serious issue. A broken spring in the compensator control valve for example. Sometimes a broken spring on the swash plate. A proper diagnosis is needed or a teardown of the pump to inspect. The piston pump is the lifting pump. The gear pump is for power steering and the gerotor pump is for the transmission, but they are all connected together as one.
Natestol
Posted: 13 Jan 2021 at 1:46pm |
Thanks, I had the head of a piston pop off on one an chew it up
Posted: 13 Jan 2021 at 3:49pm |
I'd be looking in a salvage yard. Don't think you will ever find one except thru AGCO or another AC tractor. They were designed specifically for those tractors.
Edited by DrAllis - 13 Jan 2021 at 3:49pm |
Natestol
Posted: 13 Jan 2021 at 8:09pm |
Dang I was hoping someone came up with a gear pump to replace the piston pump of something
Posted: 13 Jan 2021 at 9:45pm |
That cannot ever happen. That hydraulic system is designed to have a variable volume/variable pressure hydraulic pump. Those pumps don't fail very often. Many have been neglected over the years with few oil/filter changes.
MACK
Posted: 13 Jan 2021 at 9:48pm |
I have a piston pump that has been used very little . I can take it apart and check it out for any ware. MACk
Play Farmer
Posted: 14 Jan 2021 at 4:19pm |
I have a pump from my parts tractor that was supposed to be in good working condition.
I cannot confirm that but so far everything the previous owner said was good has been good, everything that was bad was as they said. I can get numbers off it and pictures if you'd like. |
