7020 starts hard cold and HOT |
Blustery Knoll Farm ![]() Bronze Level ![]() Joined: 04 Dec 2017 Location: Northern IL Points: 117 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Sep 2019 at 12:21pm |
This is the tractor I swapped the combine motor into last winter. It runs good and doesn't burn oil. However, it won't start below 65° unless I plug in the block heater.
Also, if I stall it while working it hard, it will not start unless I let it cool off. If I idle it a few minutes before shutting it down, it starts, but has to crank a bit with the throttle open. Any ideas what might be going on? I wonder if perhaps I have the timing just a hair too advanced or something like that. |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Check for a fuel restriction. It may need an injection pump rebuild
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8573 |
Pump head worn.....try pouring gallon of water over pump when hot or stalled and see what happens....bet it starts
One other thing. I this is the same pump that I was running on the previous motor that spun a rod bearing due to water in the oil. That motor started down to about 55°, which is what I expected for these Allis motors. Don't recall any trouble starting that one hot. But always try to cool it down a few minutes before shutting it down.
Pump head in worn, delivery valve leaking, or transfer pump pressure low.
Nothing that Ed cannot fix. MACK |
Any ideas why it started after the motor swap? Perhaps this motor has more blow by?
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Does the engine smoke a lot with white smoke after starting and until it warms up?
Yep, loots of white/grey smoke for a few minutes when it's cold.
Low compression.
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
If your not ready to tear into the engine just yet a gear reduction starter would probably help a ton. It made a world of difference on my 7060.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21751 |
Make sure the 7020 injection pump is timed at 18 degrees BTDC. Sounds like in your engine swap this might have been changed ??
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
A 301 should start good down to freezing. |
DrAllis, I did set the timing according to the shop manual. I remember 19° off the top of my head. I will double check where it is at though. I've read that the ring on the balancer can slip though, and wasn't smart enough to check what the timing marks lined up at before pulling the pump and balancer from the old motor.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5090 |
I'm with dr on this, it was better before swapping, so now you have it timed slightly different than before is my bet. As mack said, if head in pump is worn, it won't be smoking much without ether to spin it fast enough to pump fuel hard enough to pop the injectors. Also, brings those up, same injectors that were with the pump? Or replacement engines own injectors?
Ed, I am running the injectors that came with the combine motor.
If piping pressure is set higher in combine engine, a weak pump may not pop them with hot fuel. MACK
I guess I'll double check the timing and try pouring water over the pump.
If the pump is the cause, and it is weak, is there any harm in running it as it is for a while? |
No harm running it. My bet is the injectors are set much higher, now it has a hard time popping them open. Of course that is if it is not smoking much or at all during cranking. Timing could be the issue if it is smoking but not firing, assuming the engine itself has good compression. Reset timing, and run it.
Thanks for the feedback here. I just checked the timing this morning. It is right at 17.5° BTDC. Engine block at 54°F according to my infrared thermometer. It started after cranking about 30 seconds. If hard to start is the only problem, I can just remember to park it close to an electrical outlet until spring.
Edited by Blustery Knoll Farm - 05 Oct 2019 at 8:06am |
