7020 power shift operation/ engine mains/rods |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2584 |
Topic: 7020 power shift operation/ engine mains/rodsPosted: 15 Dec 2016 at 6:49pm |
the tractor has a high/low/ park position, then a tee handle with 6 speed how does it shift? this is a power shift?
was there also a need to replace the main or rod bolts on the engine because they loosen-up? dan
Edited by Acdiesel - 15 Dec 2016 at 7:34pm |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
skateboarder68
Joined: 29 Jan 2011 Location: Keota, IA Points: 372 |
Posted: 15 Dec 2016 at 7:56pm |
You have the power director, the only on the go shifting is the button I the floor you hit with your foot. Have a 7045 with same tranny and when taking off from park I take the park lever forward into neutral then go to the T handle and put it in the gear you want then go back to the other handle and put it in fast or slow range. I used to struggle shifting it but that sequence works for me everytime.
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8761 |
Posted: 15 Dec 2016 at 8:36pm |
7020 has a 301.The 426 is the one with rod bolt issues,depending on who you talk to.
Dans 7080
Posted: 15 Dec 2016 at 10:06pm |
The "t" twists it does not move side to side. The arrows will point to the gear it will be in depending if you move the t handle forward or backward. It will only twist in the neutral position.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
MACK
Posted: 15 Dec 2016 at 10:23pm |
If it has 5000 hours, it needs new rod and main bearings. MACK
Acdiesel
Posted: 16 Dec 2016 at 6:01am |
THANKS!
IT HAS THE 649I (301) ENGINE
3456 ORGINAL HOURS AND OWNER. |
