7020 fuel draining back.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: 7020 fuel draining back.
    Posted: 29 Sep 2015 at 9:35pm
If my 7020 sits for several days the fuel drains out of the lines and you have to turn on the key and run the pump and bleed it out. I thought I had it fixed by putting on a new fuel line but after sitting for about a month it did it again. Is it supposed to have a check valve or something to keep it from doing this.  Thanks JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2015 at 10:46pm
    Your fuel lines themselves would not be draining, it would be the end fittings......or....
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 7:53am
So it has an electric fuel pump? Is the hand primer still in the system? The hand primer assembly has 2 check valves in it, and they like to catch junk and get held open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 8:25pm
No it is a late model. It has 2 spin on fuel filters and an electric pump. I think the hand primers were phased out by then.JP
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 9:28pm
My 7060 did that change all lines from the tank to the filter problem gone you are leaking air in.
