7020 A/C
leader58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 A/C
    Posted: 08 Jun 2017 at 9:24pm
I was in the tractor today and A/C was fine all day. I stepped out and when i got back in, it was not working, Blower is running but compressor won't engage. Looking for tips
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:30pm
Check the thermal limiter near the compressor.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:35pm
Check the 3 wire limiter (fuse) if it is still mounted on the side of the front cover I would relocate it to front of condenser. If it is blown it will have a bubble on one side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:40pm
Is that a dealer item only?
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:44pm
get at parts house gm used them for years or put a jumper wire in to get by
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 10:06pm
I installed a new aluminum compressor a year ago. I am assuming that fuse is still in the tractor. What is the location? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 6:54am
if it is still there it should be by the compressor
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 6:56am
freon leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 12:59pm
jump low pressure switch wires and see if clutch kicks on....that'd say low on gas.They work fine till too low and shut off by low P switch
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 1:01pm
This.  Nine out of ten times this is why car A/C compressors won't kick in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:13pm
I don't think it has a pressure switch. It has a thermostat and a thermal limiter controlled by a superheat switch in the compressor unless it was changed.
