|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 7010 hydraulic pump |
| Post Reply   |
| wheelbilly   Bronze Level   Joined: 12 Sep 2009 Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Topic: 7010 hydraulic pump Posted: 21 Nov 2016 at 9:05am |
   Looks like piston pump needs replacing or repairing   What expierence have you had with this?
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 9:14am |
   I can still count on one hand how many I've ever replaced. I've fixed more for broken springs and oil leaks. What's wrong with yours?? Infrequent oil and filter changes will contribute to a piston pump internal failure.
| wheelbilly   Bronze Level   Joined: 12 Sep 2009 Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 9:23am |
   Just bought this tractor   No apparent flow at all | |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 9:33am |
   You need to connect a 3,000 psi gauge to the tee on the PTO valve and see what the stand-by pressure is (if there is any) and go from there. If you want to just go ahead and swap a pump, have at it. The tractor moves and has power steering, right ??
| wheelbilly   Bronze Level   Joined: 12 Sep 2009 Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 10:00am |
   tractor has no standby pressure at all.  how difficult is it to repair this pump?  Power steering works and tractor moves, just no remotes and 3 point does not work.  Just to repeat,  guage on pto valve doesn't show any pressure at all,  standby valve and high pressure valve in compensator are not stuck
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 10:05am |
   If low pressure standby and high pressure compensator spools are free AND their springs are not broken, I'd probably remove the pump and see if the swash plate spring isn't broken, which does happen once in a while. Before that, technically one should add some sort of shim to the low pressure compensator spool to force the pump into stroking up. If nothing happens when adding shims to the low pressure spool, there's something wrong inside the pump.
| wheelbilly   Bronze Level   Joined: 12 Sep 2009 Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 10:24am |
   Thanks Dr Allis  I have already shimmed up low pressure spool and got no response on standby pressure at all  Felt like pump problem might be next thing to consider   Your advice is greatly appreciated
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 10:53am |
   I always pulled out both belly filters first, disconnect and rotate the surge chamber line out of the way and plug it, seperate the piston pump and shove in one small plastic plug. It can sit like that for days and not lose any hyd or trans oil. Yellow 3M glue the new pump gasket in place (and let dry) and a thin film of RTV on the other side when going back together.
| wheelbilly   Bronze Level   Joined: 12 Sep 2009 Points: 51 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 5:01pm |
   Thanks for info   Will probably  be a few days  before I can get to  it
| MACK   Orange Level   Joined: 17 Nov 2009 Points: 7664 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Nov 2016 at 9:10pm |
   Agree with Dr. Have found squash plate piston come unscrewed on some .    MACK
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
